Old 03-15-2007, 10:48 AM   #1
maybe a leak
the other day I was fixing drywall near my water meter and noticed the red triangle leak indicator slightly moving when the water heater clicks on. I checked it a few more times with all water in the house turned off and sure enough a little water flows when the heater goes on. There doesn't seem to be any water leaking from the 40 gal gas unit. Is this normal??
farrington135 is offline   Reply With Quote
Old 03-15-2007, 12:59 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
maybe a leak
If you have an expansion tank near your water heater, the heated water may be going into it, allowing a little fresh cold water to flow into the heater tank.
Mike
Mike Swearingen is offline   Reply With Quote
More On This Topic
Hi! This is Kathy with City of Santa Barbara Water Resources for expertvillage.com. We are back looking at the meter again and what we are doing is looking for a leak. This meter has a leak indicator and I am going to point it out. It's this black... Read More »
Before you buy a house, it is a good idea to either inspect it yourself or hire a professional to do it for you. If you do not know what to look for, you may end up with repairs and problems you did not expect. Here are some tips on how to inspect... Read More »
Hi! I'm Cathi Pare with the City of Santa Barbara Water Resources speaking to you today for expertvillage.com. We've already looked at the meter and we determined that there was water running through the meter so the next step is we want to isolate is it... Read More »
Most people think about their water heater only when it fails. It's one of those things you couldn't live without, but as long as it does its job, you ignore it. And when it breaks down, you have no idea what to do. You can replace that old water heater... Read More »
I’m Lee. I have a degree in architecture and about ten years experience in construction field and today we are doing a kitchen remodel and we have to cut the hot water pipe back about four to five feet away from where it should be. So what you want... Read More »
HVAC/Comfortmaker leak problem notsogoodwrench HVAC 8 08-09-2007 10:59 AM
Central heat and air unit leak ? bdalekid HVAC 1 03-21-2007 08:31 AM
pipe leak & sheetrock damage santogr General Discussion 2 03-04-2007 02:44 PM
Minute Gas leak rjordan392 Plumbing 3 11-12-2006 11:59 AM
Hot water heater leak? chrisintroy Plumbing 3 02-27-2006 10:13 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
