Maximum Distance Of Sink From Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-14-2010, 07:42 PM   #1
Question
Maximum distance of sink from drain?
Attached is my schematic layout for my basement bathroom and wet bar. All fixtures are to be placed along a common foundation wall. The bathroom is already roughed in with grounds works (2" sink drain, 4" toilet drain, 2" shower drain). There is a 1.5" vent to the roof available that is also connected to the crock pit sewage ejector pump which is about 15' or 20' away from the sink drain.
My jurisdiction falls under the 2006 International Plumbing Code.
I intend to place a wet bar about 136" to the right of the sink drain (see attached schematic). How far can I go from the sink drain? I plan on running a 'revent' 1.5" pipe from the wetbar sink to the vent line.
I was told by an inspector over the phone that if I use a 2" drain pipe and an air admittance valve (AAV), I could go out as far as 120" (10'). With a 1.5" drain pipe that same distance is 8' with an AAV. Neither solution won't be quite enough for me. I am not sure if the inspector quite understood my layout as I described the attached schematic over the phone.
I also don't want to incur the expense of putting new groundworks or adding a new vent to the roof.
Is there a way for me to go out to my desired distance of 136" (11'4")?
DIYHomeTheater is offline   Reply With Quote
Tags
drain distance sink
Reversing P-trap in bathroom sink drain? DK75 Plumbing 3 03-02-2010 01:30 PM
adding new sink / faucet / drain assembly... and I'm clueless :-( diy'er on LI Plumbing 4 11-13-2009 05:36 PM
Sink Drain Stopper Won't Pop Up erclark Plumbing 7 07-11-2009 07:31 AM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
tub drain maximum distance redline Plumbing 3 08-19-2006 08:20 AM
