Old 09-09-2011, 03:17 PM   #1
Question
maximum bandwidth usage out of 1/2" pipe
can i have two toilets and a bathroom sink feed off of a 1/2" pipe. was not sure how many outlet maximum a 1/2" pipe can serve, 2 or 3. but even if only 2, i thought a toilet is a pretty light consumer + what's the chance both of them are gonna be filling the tank simultaneously.
Old 09-11-2011, 11:41 AM   #2
I don't see a problem with that, in older houses the main supply line was just 1/2 inch.
readar is offline   Reply With Quote
The Following User Says Thank You to readar For This Useful Post:
amakarevic (09-12-2011)
Old 09-11-2011, 03:10 PM   #3
1/2 water supply to both is perfectly ok and will work just fine even if they all were going at same time..
http://www.hawthornesplumbing.com
pdhawthorne is offline   Reply With Quote
The Following User Says Thank You to pdhawthorne For This Useful Post:
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 9 08-21-2011 03:17 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
Buried gas pipe in conduit WillK Plumbing 4 01-07-2011 01:50 PM
1 and 1/2" trap adapter for 2" drain pipe maxfischersweet Plumbing 5 11-19-2009 11:33 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
