Max Run For 3" Toilet Run To Main Stack - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2010, 01:37 AM   #1
Max run for 3" Toilet run to main stack
Can someone tell me what the maximum allowable run length is for a toilet to travel to the main stack in a home? Without adding a vent.
brokenhammer is offline   Reply With Quote
Old 01-27-2010, 03:02 AM   #2
where i live you cant do that nowadays bend, or. But i do know that 6 ft. is the maximum allowable developed length of the trap arm to the toilet vent here in Oregon. If i were you i would call your local jurisdiction to ask them that question about the main stack being used also as the vent.
plumbdoc is offline   Reply With Quote
Old 01-27-2010, 07:52 AM   #3
You'd have to check your local codes. Here in MA, it's 8 feet between a trap (closet bend in this case) to a vent.
Ishmael is offline   Reply With Quote
help: distance from upstairs toilet vent stack to a new downstairs 1/2 bath Heikks2002 Plumbing 3 01-15-2010 11:21 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Basement toilet: Watergenie - how to connect to main stack GD73 Plumbing 1 12-21-2009 11:13 AM
Type of pipe for main stack to septic tank GD73 Plumbing 2 08-28-2009 11:17 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
