Max Fittings In A Run? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-11-2008, 06:24 AM   #1
Wink
Max Fittings in a run?
Does anyone know if there's a rule or something to prevent me from using 4 street elbows (in a row) to tie into my 3"waste pipe. It is really the only way to come off the wall and get to the top of the waste pipe. Let me know...
Dave...Michigan
Ddave is offline   Reply With Quote
Old 11-11-2008, 10:01 AM   #2
This is one of those situations where it is so odd to do this, that there may not be a rule or code. I see a problem with clogging though.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-20-2008, 07:56 PM   #3
Yes cloggin will be an issue, are you sure its street 90's you want to use, or street 45's. Need pics
zosoplumber is offline   Reply With Quote
Propane lines in an RV...Flare Fittings K-mann Plumbing 3 09-18-2008 09:06 AM
fittings and pipes sizes.. effect on pressure? cgerikh Plumbing 3 05-19-2008 10:37 AM
iron pipe fittings farrington135 Plumbing 1 07-13-2007 08:16 PM
