Matching The Vanity With Water Supply Height - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-04-2012, 01:22 AM   #1
Angry
Matching the vanity with water supply height
I purchased 2 new vanities on special from A home center and the drawers prevent me from butting them against a wall and also not able to line p the tail pipe with p tra. Help
Terold is offline   Reply With Quote
Old 01-04-2012, 01:59 AM   #2
Not a Noob or Boob
You have two choices, move the pipes (plumber), or cut the ends of the drawers off (carpenter).
Rob1975 is offline   Reply With Quote
The Following User Says Thank You to Rob1975 For This Useful Post:
oh'mike (01-04-2012)
Old 01-04-2012, 06:02 AM   #3
DIY staff
Rewards Points: 7,174
Sadly this happens all to often---Open the wall and move the plumbing---
Old 01-04-2012, 08:44 AM   #4
MarginallyQualified
Rewards Points: 2,464
or get a cabinet without drawers (my choice)
The Following User Says Thank You to TarheelTerp For This Useful Post:
Rob1975 (01-04-2012)
Old 01-04-2012, 09:46 AM   #5
Not a Noob or Boob
You can also pull the fronts off of the drawers, pitch the drawers and nail them to the front as a false drawer. So you have several options. I would suggest next time having all your measurements with you when you purchase cabinets, and cabinets shouldn't be an impulse buy.
Old 01-04-2012, 10:35 AM   #6
MarginallyQualified
Yup, two more options to consider (after you pitch the drawers):
-put a stick (1x3?) behind the drawer opening and screw the drawer fronts to that
-cut out the drawer divider and install a door
hth
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
water coming up water supply liner candaneh Plumbing 3 03-30-2009 09:50 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
