Masterbath Addition DWV - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-11-2013, 12:57 PM   #1
Did I get this right or do I need to spend more time at a Holiday Inn? Trap to vent for the lav is less than 3 1/2 feet and less than 5 feet for the shower. Horiztonal fittings are all combos while the vertical at the lav arm to riser is a sanitee. Local code is the IPC.
Looking forward to your comments.
Thanks!
samjack is offline   Reply With Quote
Old 03-11-2013, 07:42 PM   #2
Rewards Points: 2,108
Your wet vent is over sized. The lav and tub equal 3 dfu a 2 inch drain will be needed all the way to the tub then 1 1/2 to the lav from there.
IS your vent out the roof less then 40 foot?
I assume your using IPC code. Make sure you pull permits if required.
The Following User Says Thank You to Ghostmaker For This Useful Post:
samjack (03-12-2013)
Old 03-12-2013, 10:17 AM   #3
Is your vent out the roof less then 40 foot?
Thanks for the reply and comments. I am using the IPC and the permit has already pulled. Developed length of the vent out the roof is less than 40 feet.
I will reduce the pipe size to 1 1/2 inches as indicated (meant to label that as 2-inch anyway). That'll keep me compliant on the stud penetration without using stud shoes. Revised drawing attached.
Thanks again!
"Curb" under Pier Addition Thunder Chicken Concrete, Stone & Masonry 2 08-06-2012 03:31 PM
Thoughts on this addition? sportinwla HVAC 13 04-20-2009 04:12 AM
Footing/Foundation for Addition stubits Building & Construction 1 03-11-2009 01:43 PM
!!HELP!! Rain leaking between existing home and new addition NJGirl357 Roofing/Siding 4 09-10-2008 05:06 PM
Home Addition cost? Russ Chewning Building & Construction 3 10-23-2006 07:59 PM
