Master Bathroom Shower Pressure, Weaker Every Day - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-08-2009, 11:06 AM   #1
Master bathroom shower pressure, weaker every day
The water pressure throughout the house is fine except for my master bath shower. It has been continually getting weaker and weaker for 6 months now. I'm trying to isolate the best starting point to check the lines, as I'm assuming that's where my problem is; maybe a pinched line underneath the house. I live in a manufactured home so I can crawl under the house. I don't think it's clogged. Please Help! Thx in advance, Juls
julielampp is offline   Reply With Quote
Old 09-08-2009, 11:58 AM   #2
Rewards Points: 1,016
Have you checked the shower head? Common fof the small orifaces will become partially clogged over time by mineral build up.
Old 09-08-2009, 04:15 PM   #3
I had purchased a new shower head and my husband installed it. It seems to be working fine now. Thx for your reply.
Old 09-08-2009, 08:33 PM   #4
Household Handyman
Rewards Points: 1,408
Glad to see you have the problem solved. Not only will certain minerals build up within the strainers in shower heads to cause a decrease in water "volume" and not pressure, but disturbances within municipal water (city) systems will cause very small sand and/or stones to block these filters in shower heads. If you still have the old shower head, take it apart to learn how these filters are installed and can be cleaned and reassembled. Thanks, David
Pressure Balance Shower Valve Hammer glenn60 Plumbing 7 06-17-2009 09:30 PM
What kind of wall for tiling bathroom and shower ghostdog Remodeling 1 03-26-2009 06:17 AM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 09:07 PM
Shower / Bathroom Install xlr8tn Plumbing 1 01-15-2008 05:08 PM
Master Bath Shower Remodel with images MattCoops Remodeling 4 01-10-2007 04:16 PM
