Master Bath Plumbing Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2007, 02:27 PM   #1
master bath plumbing problems
I can't afford a plumber, I am a single mom who has a toilet that has water coming out of the bottom everytime that I flush it and now it does it when I my washer spins out. Now the tub is filling with waste too. It is a mess. I have used a plunger and a snake on my toilet and my other toilet at the other end of the house too just in case but it is getting worse. What could it be and what can I do! HELP!
terri little is offline   Reply With Quote
Old 07-12-2007, 06:45 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
The mainline is plugged up, it needs to be cleaned out, rent a machine at a rental yard, but it might be better if you have it done.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
My Master Bath project ktkelly Project Showcase 23 08-07-2007 07:36 AM
Turning a Guest Bedroom into a Master Bath BbAaSsSs Remodeling 18 03-10-2007 05:03 PM
Advice on Converting Master Closet to 3/4 Bath Thirdeye Remodeling 9 02-13-2007 07:37 PM
Master Bath Shower Remodel with images MattCoops Remodeling 4 01-10-2007 03:16 PM
plumbing problems newbie needs help ? blondewolf Plumbing 2 08-30-2006 06:31 PM
