Manufacturing Defect On Buth Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-25-2012, 11:19 PM   #1
manufacturing defect on buth tub
after we installed the brand new acrylic bathtub, we found there is little water drop size bubble on the surface of the tub next to the drain; as we removed the plastic safety cover after the installation we did not notice that before the installation. now water is leaking (it is not in drops but it is like flowing!) thru that broken tip of that bubble. we tried to put silicon. but no luck. any fix??
rajibchandra is offline   Reply With Quote
Old 04-25-2012, 11:36 PM   #2
Are u able to get to the under side? maby can fix with fiber glass patch kit from bottom side. Some times just a ressin will do and you won't mess up the tub. Even if U have to cut a hole into the sheet rock wall, Sheet rock is easer to fik then replacing a tub. Hope this helps Marko
Marko6820 is offline   Reply With Quote
Old 04-26-2012, 09:06 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Don't try to fix it yourself. Call the manufacturer. They have repair people that can come look at it and probably fix it on their own dime.
Since it's already installed, it's less labor intensive to repair it than to take it out and exchange it.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
jaydevries (04-26-2012)
Old 04-26-2012, 09:07 PM   #4
Rewards Points: 582
agree with alan call manufacture they have repair companys to address these issues..should be under warranty
The Following User Says Thank You to ben's plumbing For This Useful Post:
Just ripped out a newly installed floor because of a defect in tiles and need advice! mcu Flooring 21 03-01-2012 12:02 PM
Manufacture History Roofmaster417 Roofing/Siding 6 02-23-2012 02:40 AM
Quick step Eligna Defect? GCap Flooring 5 06-26-2011 03:52 PM
American Saw & Manufacturing Co H-1 Blade? Proby Tools 17 08-13-2010 07:43 PM
