Manual Pipe Threading Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-28-2011, 09:11 PM   #1
Question
Manual pipe threading problem
I need to cut new threads on a piece of 1/2" black iron pipe.
I have a die kit [Craftsman] that has a 1/2" die.
I matched it up with a new 1/2" B.I. nipple \.
The die is too small for the O.D. of the nipple.
What size die do I need??
I just did some measuring and found that 1/2" black iron is 1/2" I.D. [I should have known that].
The O.D. is 5/8". Is that the die I will need?
cecollins is offline   Reply With Quote
Old 10-28-2011, 09:24 PM   #2
Registered User
Rewards Points: 526
Welcome to the forum!
I'll move you to "Plumbing" for a better response....
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
cecollins (10-28-2011)
Old 10-28-2011, 10:05 PM   #3
Your Craftsman set is designed to cut or repair threads on nuts and bolts - a "running thread". You need a 1/2" pipe die which cuts a tapered thread since the goal with black pipe and fittings is for the joint to get tighter as it is screwed together. (A 1/2" pipe die is only nominally 1/2" - it fits the outside diameter of the pipe.)
Ishmael is offline   Reply With Quote
Old 10-28-2011, 10:36 PM   #4
Thank you very much for your prompt and knowledgable reply.
What hardware will I need in addition to the 1/2" pipe thread die?
Old 10-28-2011, 11:31 PM   #5
http://www.plumberscrib.com/Departme...FUGo4AodbQz6mg
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 08:14 PM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 01:42 AM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 09:49 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
