-   -   Mansfield Toilet (http://www.diychatroom.com/f7/mansfield-toilet-160968/)
BOOTHA06 10-23-2012 07:42 PM
Mansfield Toilet
I have a Mansfield Toilet, tank #160, only about 5 years old. About a month ago, the toilet started running for 3-4 seconds, every few hours. After some research I replaced the red flush valve seal an the bottom of the flush valve "tower". After just a short time the same problem persisted. To confirm water wasn't leaking from somewhere else, I put red dye in the tank and withing an hour the water in the bowl was red. So, I changed the entire Mansfield flush valve...still didn't fix the problem, same issue. I then went out and bought a Fluidmaster 400AKR toilet repair kit and changed out all of the guts. An hour later and the tank is still intermittantly(sp?) filling. Does anyone have any idea why this tank is still leaking. I'm real close to replacing the toilet to avoid anymore headaches. These aren't difficult repairs, but after tearing the same toilet apart three times it's getting old!
ben's plumbing 10-23-2012 07:49 PM
I know what you mean....pia...sometimes when you change flappers it takes 3-4 flushes for new flapper to seat....put alittle vaseoline on flapper try it for a day see if it works.....I really don't like mansfield toilets...but you should still be able to repair them...ben sr
Alan 10-23-2012 09:21 PM
Pull the flapper mechanism back off again. Run your finger around the plastic opening in the bottom of the tank where the rubber ring "seats" when it's in the closed position. Hopefully it doesn't have a nick in it, sometimes they just get crud built up on them, and if you can feel it you can usually clean them off with your fingernail.
Do you by chance have any of those toiletbowl cleaners in the tank?
BOOTHA06 10-24-2012 06:21 AM
I didn't feel any nicks or imperfections and there are no toilet bowl cleaners in the tank. However, I am now confident that it's not the flapper leaking beause I emptied the tank below that level and the green dye I added continued to show up in the bowl and the water level is still decreasing.
Alan 10-24-2012 07:53 PM
How far is the bowl primer tube (the black tube attached to the fill valve) shoved into the overflow tube?
If you have it shoved in there beyond the water level of the tank, it will siphon water from the tank and dump it into the bowl.
:yes:
