Mansfield Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-28-2011, 12:26 PM   #1
Mansfield toilet
I recently bought a new bronze-look metal handle for one of our Mansfield toilets. Seemed like a simple r&r operation to swap them out. Aside from the new handle sticking out further away from the tank, now the toilet requires holding down the handle to complete the flushing. The guy at Lowe's suggested that the brass rod from the new handle weighs more the normal Mansfield plastic rod, and this is probably what's causing the the tower to descend faster. Any suggestions?
vinonut is offline   Reply With Quote
Old 09-29-2011, 08:33 AM   #2
Rewards Points: 1,578
Have you tried adjusting the flapper valve chain (might need to be a bit shorter)?
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
oh'mike (09-29-2011)
Old 09-29-2011, 09:00 AM   #3
No chain here. A plastic rod from the handle lifts the flush valve.
Old 09-29-2011, 09:31 AM   #4
Are you able to adjust that or change the flush valve to a chain driven one?
Old 09-29-2011, 09:50 AM   #5
LOL! Yes, I suppose I could - I understand I could adapt a FluidMaster flapper valve. But.... See, this is how it starts. I was just making a cosmetic change - a bronze-colored handle. Now, we're talking about replacing the tower valve. ;-)
I'd really rather find a solution to use this handle - just not sure if it's really the "extra weight of the handle" that's causing the the tower to close earlier than before.
Old 10-03-2011, 06:02 AM   #6
Call Mansfield and order an OEM handle:
Customer Service
For Questions Regarding
Vitreous China, Plastic Fittings and Parts
Phone: 1-877-850-3060
Fax: 1-419-938-6234
Hours: Monday - Friday 8-5 EST
Acrylic Whirlpools, Bathtubs, and Air Baths
Phone: 1-800-999-1459
Old 10-03-2011, 09:04 AM   #7
Bob - great minds, and all that!
I contacted Mansfield last week, and got this prompt reply:
"The Lowes associate could be correct about the weight and also the bend, is it possible you can straighten the rod, then you would probably have to cut some of it off as it will be so long. That would be the only way you might get it to work but then if it is the weight there would be nothing you can do but switch back to original lever and it does not come in bronze color, but the universal for this tank does come in Sicilian bronze, it would be model 55 SB and Lowes could order this one in for you, they can order anything from Mansfield product line."
I went ahead and straightened out the two 90 degree bends, then cut the end of the rod off. Not perfect, but works much better now.
Old 10-03-2011, 09:25 AM   #8
Glad to hear you are now happier than you were.
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 07:41 PM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
