Male Toilet Flange Question. - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-08-2013, 11:32 AM   #1
Rewards Points: 77
Male toilet flange question.
Good Day to all!
I am looking for advice whether or not to use a toilet flange that fits inside of the stack instead of over. Reason I would like to do this is that it would prevent me on having to break up the concrete around the stack.
Are there issues with clogs or any other issues that could arise by using this type of flange???
Thanks to all in advance!!
mlijoi is offline   Reply With Quote
Old 07-08-2013, 11:41 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 556
Not advised on 3" pipe- tends to clog. It's OK for 4" though
Old 07-08-2013, 11:44 AM   #3
Rewards Points: 77
Thanks for the reply!!
Old 07-08-2013, 06:03 PM   #4
CitadelBlue's Avatar
Rewards Points: 97
for what its worth .... the diameter of the plumbing leaving the toilet in most cases is 3 inches ,,,,,, so a 3 inch flange shouldn't mater ......
Just using the "progressive" flushing method ....... after going #2 flush the toilet BEFORE using the Charmin ...... After using the Charmin ... flush again .......
CitadelBlue is online now   Reply With Quote
Old 07-08-2013, 06:16 PM   #5
Plumber
Rewards Points: 556
If you want to get technical about- 3" is the smallest diameter pipe allowed for a toilet waste line
Since a 3" male flange goes inside a 3" pipe- it is therefore an illegal fitting....but the inspector will never know right?
Old 07-08-2013, 07:38 PM   #6
DIY staff
Rewards Points: 7,174
Another vote against 3" inside flanges---I have had issues with some toilet horns hitting the flange ---causing you to cut out the flange--chip the concrete and use an outside flange.
I won't touch them----outside only on my jobs.
Old 07-09-2013, 06:38 AM   #7
Lord of Slums
Rewards Points: 1,974
Maybe a picture, their maybe another way to fix your problem. I have never tried those repair flanges simply because they seemed expensive to me
mj12 is offline   Reply With Quote
toilet flange question... edselsouth1 Plumbing 2 05-01-2013 11:13 PM
Changing out carpet for tile - toilet flange? M3 Pete Plumbing 4 02-16-2012 10:20 PM
Toilet Flange Inside or Outside Drain Pipe? sledged Plumbing 23 01-18-2012 12:18 PM
Toilet flange question. speedster1 Plumbing 4 04-07-2010 10:30 AM
Toilet closet flange kensington Plumbing 5 04-27-2008 08:19 AM
