Making Holes In The Joists To Run Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-13-2007, 10:56 PM   #1
making holes in the joists to run pipe
Hi everyone!
I am planning to put a bath tub in bedroom. the house has joists going in wrong direction. plumber said he will have to make holes in the joists to run the pipe. is it a common practice and is it safe? would the inspector have any problems with this?
Also, some of the plumbers that looked at the job should replace the old pipes and old vent .... but most said i could use current pipes. What is the right thing to do?
thanks
christy123 is offline   Reply With Quote
Old 01-14-2007, 09:11 AM   #2
with Mrs. Jeep
JeepCop's Avatar
I'm by no means an expert, but from what you've said, it is common practice to run the lines through the studs/joists. They have to make it to the final destination somehow. As far as the pipes, I guess it's a matter of cost and the condition of the current pipes...
JeepCop is offline   Reply With Quote
Old 01-14-2007, 09:48 AM   #3
Journeyman Plumber
Ron The Plumber's Avatar
Drilling holes is normal, some rules apply, a plumber should know these rules, we use existing plumbing all the time, if in good shape, replacement of old pipes can get costly, your decission.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 01-14-2007, 10:21 AM   #4
thanks guys
Old 01-14-2007, 05:03 PM   #5
747
registered
747's Avatar
Rewards Points: 534
If the pipes are copper i would keep them. If there galvanized i would consider having them replaced with copper. Galvanized pipes will corode on the inside if there old.
747 is offline   Reply With Quote
Old 01-20-2007, 03:05 PM   #6
Is there a maximum size hole you can drill? ie. 1/4 of the joist depth....1/3 of joist?
tdferguson is offline   Reply With Quote
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
Wood Burner Installation Question? fisher501 HVAC 1 12-22-2005 09:29 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
Spacing of ceiling joists Pineconeman Building & Construction 3 05-13-2005 11:16 PM
