Major Shower Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-03-2012, 05:24 PM   #1
Rewards Points: 52
Major Shower issue
We knew we had a leak, but thought it was the seal. Instead we found this:
Then we found this:
If you notice about 1 oclock position, the mortar and foundation is gone! So what do you guys propose for me?
digitalplumber is offline   Reply With Quote
Old 11-03-2012, 05:28 PM   #2
funfool's Avatar
Rewards Points: 534
I dunno, little duck tape should fix that.
funfool is offline   Reply With Quote
Old 11-03-2012, 05:36 PM   #3
Rewards Points: 13,300
If that first picture is of the bottom of the shower pan, this has been going on for a while.
Looks simple enough.
Repore the floor to get it level, water proof it, install new pan.
Most pans I've installed require blobs of morter be placed to support the bottom of the pan so it does not crack like that one did.
Old 11-03-2012, 05:47 PM   #4
funfool's Avatar
Rewards Points: 534
Good point joe, looking at the photo I assumed pan was already removed.
Then looking at the poster, was a non issue to do it right, toss in a little humor.
But if was no mortar bed under it to support it, could be why it failed in the first place.
Old 11-03-2012, 05:55 PM   #5
Duct tape bad. Morter good.
Old 11-03-2012, 06:01 PM   #6
Rewards Points: 52
My question is, I am seeing clear water in the 1 o'clock position. I am also getting clay!
I think it needs to be jacked out around the drain and re poured?
What do you think?
Also, no there was no mortar anywhere! I think they thru down what you see, squashed the pan down and ran laughing saying it a be years before this guy finds this out!
digitalplumber is just a name for use here, I am not a plumber!
Old 11-03-2012, 06:09 PM   #7
You may well be right.
And your right on the way to fix it.
While your digging it out make sure they at least put in a trap, make the pore at least 4" thick, wrap some foam or nylon 1/2 rope around the drain before poring so it has room to flex.
Old 11-03-2012, 06:11 PM   #8
DIY staff
Rewards Points: 7,174
Obviously that shower needs rebuilding----
You have many options------
Fiberglass pan----cheap and serviceable---but plain and looks worn after a few years
Cast onyx pan----sharp looking --moderately expensive---many colors available--
Tiled pan-----several methods of building one-----pricy , but can be very attractive----
What is your budget? Are you a DIYer or more likely to hire the work out?
Old 11-03-2012, 06:12 PM   #9
Rewards Points: 52
There is a trap
Old 11-03-2012, 06:13 PM   #10
Rewards Points: 52
DIYer no budget.
Old 11-03-2012, 06:18 PM   #11
Rewards Points: 52
Should the trap be encapsulated within the cement foundation?
Old 11-03-2012, 06:55 PM   #12
DIY staff
How to build a shower - Building a shower pan with pre-sloped mortar bed, liner and curb.
This is the standard packed base-----cost in materials about $135---not including tile----
Drain with square cover---PVC sheet membrane---masons mix or make your own mud----
Then add Durrock for the walls----new shower mixer valve (if needed) --Red Guard or Hydroban waterproofing for the walls---
Tile and grout----
Old 11-03-2012, 07:47 PM   #13
Rewards Points: 52
Tile and grout----
Thanks, what I need to determine first is what to do about the drain?
This was a new home when we bought it and don't understand why this drain appears to have been cut out? And poorly filed in?
But need to deal with the drain and leveling first.
Old 11-03-2012, 09:13 PM   #14
DIY staff
Can you take a picture from further back---include the base too--
I see a fiberglass base---do I also see the concrete pad that it used to sit on?
Old 11-03-2012, 09:16 PM   #15
Plumber
TheEplumber's Avatar
Rewards Points: 452
Break out the concrete patch and make sure PVC riser extends high enough for a new fiberglass shower unit. Pour back concrete, leaving room for the pipe to flex some. Allow clearances for the shower drain assembly (notice the nut impression). If you're going with a mud base, the prep is similar but a different drain body
The Following User Says Thank You to TheEplumber For This Useful Post:
digitalplumber (11-03-2012)
Trane XR90 issue jasun HVAC 7 10-08-2012 07:18 PM
HVAC condensor fan outside intermittant wheelsup HVAC 21 05-24-2012 11:25 AM
Westinghouse furnace issue joe8918 HVAC 9 12-04-2011 06:50 PM
how to reduce mositure issue on basement? diy001 Building & Construction 0 10-28-2011 01:44 PM
Perplexing AC issue AvalonGirl HVAC 22 08-17-2011 07:49 PM
