Major Issues Fitting New Drain To Bathroom Sink. - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-15-2015, 01:13 PM   #1
Rewards Points: 6
Major issues fitting new drain to bathroom sink.
So Iím replacing a bathroom faucet. Faucet went on no problem. The drain however, is not going so smoothly. The previous drain was the metal popup kind. The new one is a Pfister push & kind.
Now, this drain comes with a rubber gasket that is supposed to sit in the sink bowl, under the flange. The manufacturer expressly says not to use plumbers putty.
The problem Iím having is with my sink! There are two issues:
1) The sink is uneven so the drain does sit flush; as I tighten the assembly underneath, the drain pulls to the right.
2) There isnít a recess that accepts the rubber gasket AND the flange, so both sit above the bottom of the sink. It seems like thereís some kind of ring of epoxy or plastic where the rubber gasket would otherwise nestle into.
I've attached pics.
So, what are my options? Ditch the top/sink side rubber gasket and use silicone? Try to remove that interior ring of material and hope the gasket and flange will fit into it and sit lower in the sink bowl?
Iím at a loss!
Major issues fitting new drain to bathroom sink.-drain01.jpg   Major issues fitting new drain to bathroom sink.-drain02.jpg
ben_allison is offline   Reply With Quote
Old 11-15-2015, 01:47 PM   #2
Property Mgt/Maint
Rewards Points: 1,554
forget the gasket and use plumbers putty
Yodaman is online now   Reply With Quote
Old 11-15-2015, 01:47 PM   #3
Rewards Points: 320
Usually the gasket goes underneath the sink and you put plumbers putty under flange, make sure its even while tightening it down. Just a suggestion.
jmon is offline   Reply With Quote
Old 11-15-2015, 02:01 PM   #4
Rewards Points: 6
There are two gaskets: a smaller one that's supposed goes in the bowl, and another much larger one that goes underneath to form the seal.
I believe the assembly is plastic, so plumber's putty isn't recommended (it can eat away at the assembly over time).
I'm considering just getting a different drain at this point. The faucet doesn't allow for the popup style drain, so I might just get an old school drain that has no included drain stop mechanism.
The Following User Says Thank You to ben_allison For This Useful Post:
jmon (11-15-2015)
Old 11-15-2015, 02:13 PM   #5
Rewards Points: 26
I usually use caulk instead of plumbers putty now a days. I think I would try and caulk the drain to the sink.
ponch37300 is offline   Reply With Quote
Old 11-15-2015, 02:26 PM   #6
Rewards Points: 320
The second picture you posted with red arrows looks like a combination of old plumbers putty, silicon and a washer that needs to be scraped off.
Old 11-15-2015, 08:44 PM   #7
Rewards Points: 2,040
Use 100% clear silicon caulk. Not the water based stuff.
Tags
drain , gasket , sink
Condensate Drain Line Mystery FrogFan HVAC 5 09-24-2015 09:27 PM
Bathroom sink drain smells like eggs Richo Plumbing 13 04-09-2013 11:16 PM
Bathroom sink drain pipe on the side of the wall amandanory Plumbing 7 11-17-2012 10:27 PM
Can bath sink and service sink drain into 1.5" branch drain hammerlane Plumbing 29 11-16-2012 02:37 PM
Bathroom sink drain min. drain size mlijoi Plumbing 2 11-15-2012 10:48 AM
