maintenance free battery back up
So when you loose your normal AC power, the backup battery can keep the sump pump running....I'm sure you would really understand why if you had a power failure....and your basement started to fill up with water......
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
