-   -   maintenance free battery back up (http://www.diychatroom.com/f7/maintenance-free-battery-back-up-158646/)
macdhb 10-01-2012 10:35 PM
What is the reason for not using a maintnenance free battery in the watchdog back up sump pump
ddawg16 10-02-2012 01:19 AM
So when you loose your normal AC power, the backup battery can keep the sump pump running....I'm sure you would really understand why if you had a power failure....and your basement started to fill up with water......
joecaption 10-02-2012 07:05 AM
If the question is why not use a mantance free battery instead of a wet cell there is no good reason other then the higher cost of the battery.
ddawg16 10-02-2012 10:11 AM
I'm confused now.....
Is the question "Why use a battery"
or "Why not use a maint free battery"
or "It should have been a maint free battery"
or ???????????????
