Main Water Valve Seized - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-19-2009, 06:03 PM   #1
Main water valve seized
I am replacing the drywall in one of our bathrooms and I need to shut off the water to take the taps off the tub and shower. Problem is that I can't get the main water valve coming in the house closed. It seems to be seized. I do not want to break anything but I cannot complete my project till I get this valve closed. Any tips, tricks or miracle lubes that I can use to fix this problem?
techie34 is offline   Reply With Quote
Old 04-19-2009, 07:09 PM   #2
If it is a gate valve, try loosening the nut under the handle about 1/2 turn. This may allow you to turn the handle. Since main shut-off valves do not get used much, it is typical that they corrode inside. You may also want to try tapping (not beating) on the bottom of the valve while you put pressure on turning the handle.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 04-20-2009, 07:11 AM   #3
Rewards Points: 150
If you have a outside water meter you can turn it off there. if on well turn power off to pump.
al's sewer is offline   Reply With Quote
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
can't shut off cold water from main disconnect DanBress Plumbing 3 01-06-2008 06:20 PM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 02:17 AM
leaking water main LanterDan Plumbing 4 08-31-2006 07:24 AM
