Main Water Valve Or Pressure Regulator - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-18-2011, 04:12 PM   #1
main water valve or pressure regulator
the main valve or water pressure regulator is malfunctioning, it periodically squirts water form the valve and causes the water pressure to go out or stop altogether. Do I need to replace the valve and how much would the cost be.
kzwbvn is offline   Reply With Quote
Old 10-18-2011, 04:38 PM   #2
Rewards Points: 502
is this a well thing?
forresth is offline   Reply With Quote
The Following User Says Thank You to forresth For This Useful Post:
kzwbvn (10-18-2011)
Old 10-18-2011, 05:17 PM   #3
Plumbling
No it is not. It's the main valve that turns all of the water on and off in your home. It's called a Pressure Regulator Valve or Pressure Reducer Valve.
Old 10-18-2011, 06:53 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 914
sounds like a RPBP assembly (reduced pressure backflow preventer)
Get a model number off the unit and google it for prices. They are easy to replace but it needs to be certified by someone approved or licensed
Old 10-21-2011, 04:47 AM   #5
Rewards Points: 400
Or possible even repaired by a licensed plumber
fireguy is offline   Reply With Quote
Old 10-21-2011, 06:40 AM   #6
Rewards Points: 1,548
If not already, you need an expansion tank, preferably installed near the water heater.
Lacking that, it is possible for unusually high pressures to develop and the main shutoff valve may have been the weak spot in your situation.
Water Pressure issues after repairing main water line. Cleve99 Plumbing 2 01-26-2011 07:13 PM
New shower valve.. No water pressure? wilson5307 Plumbing 2 03-11-2009 10:10 PM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
