Main Water Valve Leakage - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-09-2012, 12:55 PM   #1
main water valve leakage
We turned off the water main to change a leaking hose on a toilet. When we turn the water main back on, water is pouring out of a cone shaped pressure valve adjacent to the water main shut off lever. There are 4 holes in the fitting that attaches to the bottom of this valve. Is this normal? Will the water dissapate if we let it run long enough? Upon further inspection, this valve is called a trap primer valve.
sharon@shadsnet is offline   Reply With Quote
Old 07-09-2012, 10:50 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 986
Mechanical trap primer, turn the water on and off a couple times may re seat if not will need to be replaced.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 07-10-2012, 12:23 AM   #3
Rewards Points: 13,244
Why was there not a shut off valve on the supply line right behind the toilet?
There needs to be on on the hot and cold on every fixture.
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
water damage from high pressure aeldien Plumbing 9 04-16-2012 12:21 PM
Main water valve in condo shut off, but neighbors can still hear water running through pipes. cookiebird87 Plumbing 1 12-01-2010 05:43 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
