Main Water Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-24-2012, 06:55 PM   #1
Rewards Points: 111
Main Water Valve
Hi, I need to replace my main water valve. How do I shut off the water from the street?
suncowiam is offline   Reply With Quote
Old 06-24-2012, 06:58 PM   #2
MarginallyQualified
Rewards Points: 2,464
Common hand tools are often plenty but a "meter key" makes it far easier.
Lowes and HD sell them. About $10us
here's a video:
Old 06-24-2012, 10:18 PM   #3
Rewards Points: 111
Thanks!
Old 06-25-2012, 06:38 AM   #4
A word of caution, if you damage the street valve, you pay for its' repair.
What I usually do is crank the old valve down as tightly as possible. there are expandable stoppers or the old bread trick to stop the leakage while soldering. Cut the pipe above the old valve, use the stopper. Better yet, us a compression or sharbite valve(always use a ball valve), on in a few seconds.
Old 06-25-2012, 07:36 AM   #5
DIY staff
Rewards Points: 7,174
I suggest that you call the village and have them turn on or off the valve--
Like Daniel mentioned--if it breaks you pay if you touched it--they pay if they touched it--
Best if they pay---
Old 06-25-2012, 03:56 PM   #6
Rewards Points: 111
actually, i found on youtube that if i tighten the nut right down the wheel handle, then i can fix the leak. that was where my leak was coming from.
all fixed, although i still have a pretty old gate valve but still working now.
thanks everyone!
Old 06-25-2012, 04:43 PM   #7
Rewards Points: 13,694
Still replace it though with a ball valve asap so if there's a major leak one 1/4 turn and it's off.
plummen (06-25-2012)
Old 06-25-2012, 05:36 PM   #8
Rewards Points: 111
Not completely sure but I believe I will have to cut the piping to install a ball-valve. Is this an easy thing to do?
The Following User Says Thank You to suncowiam For This Useful Post:
oh'mike (06-25-2012)
Old 06-25-2012, 05:58 PM   #9
Rewards Points: 3,622
thanks everyone!
And the next time it starts to leak,back that nut all the way off and put some new packing in then retighten,no need to replace.
Canarywood1 is offline   Reply With Quote
Old 06-25-2012, 09:22 PM   #10
DIY staff
If the piping is copper---no big deal at all--if it's threaded steel pipe--you have a challenging job.
Good idea to get a ball valve into the line--it's not uncommon for the old gate valves to break--in the off position--Mike--
Old 06-25-2012, 11:02 PM   #11
Rewards Points: 111
it's threaded steal pipe. =)
Old 06-26-2012, 06:51 AM   #12
Rewards Points: 1,216
Call the water Company and tell them you are having the main valve replaced, schedule a time for them to shut off the water and then a return time to turn it back on, get all your stuff ready including new valve, cut out old valve and install new valve. Don't mess with the old valve it's not worth it because it will only come back to haunt you later.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
TheEplumber (06-26-2012)
Old 06-26-2012, 07:29 AM   #13
Old steel pipe can and does have a lot of issues.
At some point it is going to fail and leak, it rust from the inside out. As it rust the flow slows down.
It also adds to rust stains showing up on all your fixtures.
It shortens the life of faucets and water tanks.
Old 06-26-2012, 12:55 PM   #14
Rewards Points: 111
I have a pipe cutter for 3/4" copper piping. I'm assuming this won't work on steel. Regardless the piping is an inch wide but curious on what cutter to use. Also, will I have to solder the gate valve or could I still find a threaded solution?
If I need to solder do I have to use flux on steel? Never worked with steel before.
I have a bunch of projects and the leak was my first priority. Just need to correctly place this into my queue of things to do. I'll try to get some pictures of the valve and piping soon.
Thanks!
Old 06-26-2012, 01:02 PM   #15
Plumber
TheEplumber's Avatar
Rewards Points: 664
Please do upload some pics.
Working with threaded pipe is actually pretty easy. No soldering involved and you cut it with a hacksaw, sawzall or tubing cutter designed for iron pipe.
Any valve in available in iron pipe thread pattern.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Hot Water Heater Problems Btabach Plumbing 7 05-21-2012 01:24 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
