Main Water Supply Valve Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-31-2009, 08:19 AM   #1
hohadcr's Avatar
Rewards Points: 346
main water supply valve leaking
The main water supply valve is leaking. It is where water comes from the city. If it is turned on, it leaks. Can I change the valve my self? Or it is the city's respossibility? Thanks for your input.
hohadcr is offline   Reply With Quote
Old 07-31-2009, 08:26 AM   #2
what type of valve? where is it leaking ? is it the packing ? brass copper steal lead ?
metx is offline   Reply With Quote
Old 07-31-2009, 08:31 AM   #3
hohadcr's Avatar
Rewards Points: 346
The valve is the old type where the handle is a round one and you have to turn a lot of rounds to turn it on or off. I would guess that the valve is brass. The water supply pipe is galvanize I believe.
The leak, i believe, is from the middle axle, which turns with the handle.
Old 07-31-2009, 09:34 AM   #4
Turn off the water at the street, open all faucets above this valve, disassemble the valve, wait for all the piping water to drain out into a large bucket and replace the valve stem packing.
While you're at it, replace the 1" diameter washer and make sure the washer seat is not damaged.
Old 07-31-2009, 09:45 AM   #5
Remodeler
adpanko's Avatar
Rewards Points: 150
You might just be able to tighten the packing nut. There should be a hex nut surrounding where the "axle" goes into the body of the valve. Is the leak coming from that nut? If so, you can most likely just snug that a little tighter.
adpanko is offline   Reply With Quote
Old 07-31-2009, 10:21 AM   #6
hohadcr's Avatar
Rewards Points: 346
How to turn off the water from the street? Should I contact the city for that?
Old 07-31-2009, 10:30 AM   #7
It is best to have the City do the turn off. If the valve breaks, even if it isn't your fault, you pay for the repair.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 07-31-2009, 11:49 AM   #8
you have a gate valve .it sounds like the packing ,open valve all the way the back off slightly the tighten the nut that holds the stem .
Old 07-31-2009, 11:59 AM   #9
At my house there is a 1' dia. round plate flush with the ground secured by a 5-sided nut. Turn the nut one turn with pliers and it releases the plate. Don't drop the plate into the opening.
An arm's length under this plate is the meter and a valve with no handle, just a rectangular raised area. Turn this valve 1/4th turn CW with pliers or a Vice-Grip. Don't break the valve or the meter.
I hate waiting for utilities to show up at my house and when I was losing one gallon in 3 minutes due to a pinhole leak I had to get access to the meter.
http://www.flowmeterdirectory.com/im...ater_meter.gif
Old 07-31-2009, 04:21 PM   #10
Rewards Points: 1,088
You can buy a key at a big box retailer. I've seen them at Ace Hardware...~$9.99.
Personally for me, I would try to tighten the packing nut.
If that doesn't work, I would call a plumber.
I would not mess with trying to solder a water main valve onto the feed into the house.
handy man88 is offline   Reply With Quote
Old 07-31-2009, 06:27 PM   #11
I am confused where is it leaking from the valve? or the pipe ?or the meter ? show a picture . you said a pin leak ? the threads to the gate valve ?
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
water heater PRV valve leaking econdave Plumbing 20 09-02-2008 07:01 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
