Main Water Shutoff Valve Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2012, 10:45 AM   #16
Rewards Points: 24
Originally Posted by jagans View Post
Since you are working with copper, and a plumber is coming out anyway, you may want to have him sweat in a coupling and raise that valve, and also put in a T with a curb cock, so you can cut off the water at that valve and drain your house back to that low point through the curb cock into a couple of buckets, in case you need to do any other work. This might sound funny to some but I have one with a hose connected inside, just in case I start a fire in my basement shop
Stop thinking/reading my mind
I had the exact same thought! I definitely want the valve a little higher off the slab...don't know why the original plumber did that way.
obadran is offline   Reply With Quote
Old 12-10-2012, 11:45 AM   #17
Missouri Bound's Avatar
Should I even ask what you do that can start a fire in your shop.....or is it a "lab"?
Do you want it your way or the right way?
Leaking water main shutoff valve Witz Plumbing 5 09-23-2012 09:06 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Leaky ball valve at incoming water line Bipin1948 Plumbing 5 10-03-2011 05:21 PM
Main water shutoff problem GoodoleBob Plumbing 18 06-16-2011 10:33 PM
