Main Water Shutoff Valve Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-09-2012, 10:18 AM   #1
Rewards Points: 24
Main Water Shutoff Valve problem
My main water shutoff valve, I think is a open globe type valve with a drain nipple on it. It's not a quarter turn value. My house was built in the late 60's.
I had to shut the water off so I could put new shutoff valves in a half-bath that I'm remodeling. When I went to turn the main valve back on, I noticed that the gland nut/packing nut was also turning. After tightening it back up, I couldn't turn the handle....loosened it back up a little and held the nut with the channel lock pliers, still can't turn the handle...it's like it is totally seized up.
I've turned the main valve on and off a few times before and never had this problem, but then maybe I never noticed the gland nut turning as I turned the valve. Also, the valve is just really hard to turn to begin with.
Is there a way to fix this without having to have the water company turn off the street valve and pull the whole valve assembly out? Or is it better to just get a whole new valve assembly. I'm assuming you can just replace the valve assembly without getting a whole new valve.
If the gland nut were to come off while the valve in on, would water gush out or would it just seep out? Right now it's seeping because I had to loosen the nut so I could get the water turned on enough to have good water pressure.
Thanks,
Omar
obadran is offline   Reply With Quote
Old 12-09-2012, 10:27 AM   #2
Rewards Points: 13,968
Needs to be replaced with a ball valve.
Globes all leak or fail.
No need to call the water company, open the cover where the valve is and just turn the valve off. If it's way below ground then go buy one of these.
http://www.bing.com/images/search?q=...+shut+off+tool
Old 12-09-2012, 10:50 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 796
If a gate or globe valve is properly maintained, they last a long time- but no one takes care of them until its too late. I have 80 yr old gate/globe valves work as good as the day they were bought.
You could call the water dept, take the guts out and attempt to repair it but you're best bet is to replace it. A ball valve will out last you.
Old 12-09-2012, 12:02 PM   #4
Roofmaster
Rewards Points: 2,210
Gate Valve
Have the water company kill it at the curb and install an American made, all brass gate valve. This will probably make a difference in your pressure, too. When you open the valve, open it all the way and then turn it back in a quarter turn.
Old 12-09-2012, 12:35 PM   #5
Also remove all your eriators on all the faucets and your show head before turning the water back on. There will be trash knocked loose in the line that will plug them up.
Just flush out the lines and put the back on.
Old 12-09-2012, 02:39 PM   #6
Roofmaster
Over Kill??
That may be over kill, Joe, If they flush out at a basement laundry sink that should do the trick, as the crud will flow to the first demand. I guess it would'nt hurt to check them though, if theyre not cross threaders LOL
Old 12-09-2012, 05:00 PM   #7
Rewards Points: 24
Thanks for the advice.
Now I need to decide, for the sake of time, do i just get a plumber or do it my self. Any ideas on ball park prices to replace a valve?
Old 12-09-2012, 05:33 PM   #8
Roofmaster
Advice
My gut says if you have to ask, get a plumber, This is your main water supply valve, you gotta get it right the first time, and they usually have the tool to turn off the valve at the curb. Again, American Made Gate Valve.
Old 12-09-2012, 06:17 PM   #9
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Is it on the street side or house side of the meter?
If you do call the utility to turn it off at the street Id go ahead and replace the valves on both sides of meter with new ball valves
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 12-09-2012, 06:26 PM   #10
Rewards Points: 24
The valve is house side and the main pipe come up through the slab and the valve is like 2-3 inches above the slab.
The old valve will have to be removed by "un-sweating" it since if it is cut off, that just leaves less pipe sticking above the slab to work on. I just don't have it in me to mess with that
I think I'm going to go with Jagans advice...get a plumber...get it done right the first time.
Old 12-09-2012, 06:34 PM   #11
plummen's Avatar
Normally around here anyway we have a valve between wall/floor and meter(street side) and one on other side of water meter (house side),of course most of our meters are in basement anymore.
Old 12-09-2012, 09:26 PM   #12
Roofmaster
Plumber
Since you are working with copper, and a plumber is coming out anyway, you may want to have him sweat in a coupling and raise that valve, and also put in a T with a curb cock, so you can cut off the water at that valve and drain your house back to that low point through the curb cock into a couple of buckets, in case you need to do any other work. This might sound funny to some but I have one with a hose connected inside, just in case I start a fire in my basement shop
The Following User Says Thank You to jagans For This Useful Post:
plummen (12-09-2012)
Old 12-09-2012, 09:46 PM   #13
Missouri Bound's Avatar
Good idea....and if you want to learn how to solder pipes you can learn on something less critical or less important than your main water supply.
Do you want it your way or the right way?
Old 12-09-2012, 11:10 PM   #14
No soldering needed.
http://www.sharkbite.com/usa/product...&category_id=7
Old 12-10-2012, 06:26 AM   #15
Rewards Points: 1,216
I wouldn't use a shark bite there because it's so low to the slab and the unsweated copper needs to be perfectly clean for the valve to fit and seal. One little dimple in that main supply could cause a lot of problems with that shark bite.
I have seen water lines the same as described in closets with people dropping shoes, boxes and everything under the sun on the meters and valves that's why I would want nothing but a soldered valve in place at the main. Not saying sharks are bad but I wouldn't use them on every application that came along.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Leaking water main shutoff valve Witz Plumbing 5 09-23-2012 09:06 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Leaky ball valve at incoming water line Bipin1948 Plumbing 5 10-03-2011 05:21 PM
Main water shutoff problem GoodoleBob Plumbing 18 06-16-2011 10:33 PM
