Main Water Shutoff Valve Leak & Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-11-2012, 01:22 PM   #1
Main Water Shutoff Valve leak & question
This is one of the various fixes I'm doing on my new/old house.
My main water shutoff valve looks basically just like this, except a lot older:
I just tightened the packing nut and the leak seems to have stopped for now, although I'm not fully confident its 100% fixed yet. So I guess the next step is replacing the washer.
As I understand it, I can first close the valve to shutoff the water and then remove the handle & nut to replace the washer.
I just wanted to make sure this is correct procedure and water won't be shooting out as soon as I remove the packing nut, since its the main shutoff and I don't have any other shutoff valves located before this one (not even a curbside one at the meter).
thanks!
leemort is offline   Reply With Quote
Old 02-11-2012, 01:37 PM   #2
Water Treatment
Rewards Points: 816
I my self would not go to the bank on that.
What is to keep the gate in place when you remove that outer nut to replace the packing nut?
Akpsdvan is offline   Reply With Quote
Old 02-11-2012, 01:37 PM   #3
DIY staff
Rewards Points: 7,174
That's the method----the packing looks like a Teflon covered string---not a washer-
Old 02-11-2012, 01:58 PM   #4
So you're saying what I described is the way to do it?
Just making sure since the reply above from Akpsdvan is advising against.
Thanks for the tip on the packing
Old 02-11-2012, 02:03 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
plummen is offline   Reply With Quote
Old 02-11-2012, 02:04 PM   #6
Lightfoot's Avatar
Rewards Points: 272
I'd shut the water off at the meter and change that out for a 1/4 turn ball valve.
Lightfoot is offline   Reply With Quote
Old 02-11-2012, 02:12 PM   #7
yeah, I figured my closing/opening of the valve is what caused the leak to start.
Unfortunately I don't have any shutoff valves at the meter, so I would have to get utilities to come out and shut it off on their side. The only main shutoff I have is the one that was dripping. It still appears to have stopped the drip after I tightened the nut, so maybe that will fix it afterall.
There aren't any shutoff valves for any of the sinks, toilets, showers, etc in this house- a bit aggravating. I think one of my next projects will be installing them all. Adding a ball valve at the meter would be excellent
I'm sorry to be so thick headed here, but I'm still not clear on if its safe for me to remove the handle/packing nut on the main shutoff after closing, or if I will need utilities to shut my water off first?
Old 02-11-2012, 02:26 PM   #8
plummen's Avatar
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
Old 02-11-2012, 02:27 PM   #9
Rewards Points: 150
why even bother repairing this old valve? go to home depot and pick up a ball valve for 7 bucks and sweat it in.
alecmcmahon is offline   Reply With Quote
Old 02-11-2012, 04:58 PM   #10
Rewards Points: 1,088
The stem of the gate valve is held secure via the internal metal threads of the valve itself. The stem will not shoot out after the packing nut is removed.
handy man88 is offline   Reply With Quote
Old 02-11-2012, 05:05 PM   #11
Rewards Points: 12,840
Not a big deal to shut the water off at the meter out in the yard and no need to call the utility. I just use an adjustable wrench and turn it 1/4 turn.
Old 02-11-2012, 05:15 PM   #12
plummen's Avatar
Old 02-11-2012, 05:24 PM   #13
Is that to get them below the frost line?
Must have to use one of those long Tee handles to get to those.
Old 02-11-2012, 05:31 PM   #14
plummen's Avatar
Old 02-11-2012, 05:45 PM   #15
Plumber
TheEplumber's Avatar
Rewards Points: 350
Originally Posted by plummen View Post
Yes sir,ive got several of them from 8-10' long just incase
Same here but I don't like to use them. Ever had to buy a broken curb stop? Better to leave it to the water co.- let them break their stops.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Main water shutoff problem GoodoleBob Plumbing 18 06-16-2011 11:33 PM
main cutoff valve does not stop water completely lpbaraldi Plumbing 12 09-07-2010 10:46 AM
toilet shutoff valve not getting water JackyS Plumbing 4 11-23-2009 08:29 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
