Main Water Shutoff - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-07-2013, 10:06 AM   #1
Rewards Points: 35
Main water shutoff
I am asking this on behalf of a friend in Alabama, where I believe the frost line is 12" below grade. She has a house with a crawl space which is not easily accessible. The main shutoff is outside and requires a special tool to manipulate. Could it be replaced with a long stem valve with a standard manual handle accessible from above grade, or will the metal of the valve stem conduct heat enough to potentially bring frost to the water line?
ex-Khobar Andy is offline   Reply With Quote
Old 07-07-2013, 12:18 PM   #2
MarginallyQualified
Rewards Points: 2,464
That sounds like a meter box and "meter key".
Lowes sells the tool for about $10. Get one
Could it be replaced with...
**IN ADDITION** to the meter key there should ALSO be a valve on the main water line coming into the house and located somewhere that makes sense like near the water heater or under the kitchen sink.
If there isn't one... add it.
hth
The Following User Says Thank You to TarheelTerp For This Useful Post:
oh'mike (07-07-2013)
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Distance of water heater from incoming cold water main ncrango Plumbing 3 02-14-2012 11:15 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
