Main Water Shutoff - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2012, 09:06 AM   #1
Main water shutoff
I have never had to shut off my main water valve before. I just bought my house a few yrs ago. My bathtub faucet is leaking and I've been told the o rings may need replaced. I've found some how to videos on that. The problem is when I tried to turn the water off the valve wouldn't budge. It's inside my house. Is it ok to force it?
cindyg351 is offline   Reply With Quote
Old 02-19-2012, 09:09 AM   #2
Rewards Points: 13,968
You should have posted in the plumbing area for better replys. Also a picture really helps.
City water or your own well?
Old 02-19-2012, 09:15 AM   #3
Experienced
Jackofall1's Avatar
Are there no shut offs under the sink?
I really doubt that a shut off under the sink would turn the bathtub water off.
Post a picture of the valve if you can. When you say force the valve, what are you planning to use to force it? By hand as much force as you can, with a pipe wrench be careful.
Mark
Old 02-19-2012, 09:57 AM   #4
I will post in there also. New member. Thank you. It's not under the sink, it's the main one coming into the house. It's an actual knob, and when I try to turn it by hand it doesn't move. Maybe I should call a plumber. I was just trying to save the expense. Thanks for replying
Old 02-19-2012, 10:02 AM   #5
Experienced
Jackofall1's Avatar
If you are not familiar with what valve can sustain as related for force it is possible to twist off the stem if too much force is applied to it. Generally once you get the valve to start turning it will loosen up and you will be able to close it.
Being the main shut-off could be tricky as if you break it, you will need to shut off the water outside and that usually take the county or city to come out.
Mark
Old 02-19-2012, 10:04 AM   #6
Main water shutoff
I have never had to shut off my main water valve before. I just bought my house a few yrs ago. My bathtub faucet is leaking and I've been told the o rings may need replaced. I've found some how to videos on that. The problem is when I tried to turn the water off the valve wouldn't budge. It's inside my house. I don't have a valve going to the tub that I can get to so I have to turn it off at the main. Is it ok to force it?
Old 02-19-2012, 10:09 AM   #7
Thank you Mark. I'm willing to try most things myself if I can, but maybe I will get the yellow pages for this one
Old 02-19-2012, 10:43 AM   #8
Rewards Points: 152
You might want to replace that main shutoff. If you ever had a big leak (ie. burst pipe in the middle of the night), it's important that you can shut it off yourself immediately instead of having to wait for the municipality to come shut it off at the street.
If it were me, I'd contact the municipality to see about getting the water shut off at the street. Then, cut out the old valve, install a new 1/4 turn ball valve (or call a plumber to do it) and you'll be good to go for years to come!
burnt03 is offline   Reply With Quote
Old 02-19-2012, 12:22 PM   #9
Thanks for the advice
Old 02-20-2012, 05:04 PM   #10
I was able to get help getting water turned off. Changed o rings and water still leaking. Ideas?
Old 02-20-2012, 06:15 PM   #11
Rewards Points: 674
Are you sure you got the right ones? There are quite a few different sizes and types. Did you take the old ones in with you?
B
Beepster is offline   Reply With Quote
Old 02-20-2012, 06:31 PM   #12
Rewards Points: 636
picture of faucet would be nice then someone can go into more detail on fixing drip for that type of faucet
jaydevries is offline   Reply With Quote
Old 02-20-2012, 07:04 PM   #13
Thought it was cold leaking. Changed both hot and cold and it's slow to stop running when shut off, but so far has stopped leaking. I am using my iPod to post and it doesn't have a camera for me to add a picture. It's a basic kohler faucet u would find in apartments. 3 knobs with clear plastic, one is for shower. In any case, hope it doesn't start back up again and thanks for replies.
Old 02-20-2012, 07:11 PM   #14
Rewards Points: 636
sounds great or should i say no sounds "water dripping" great
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Distance of water heater from incoming cold water main ncrango Plumbing 3 02-14-2012 11:15 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
