Old 11-18-2012, 08:08 AM   #1
main waste line repair in basement
I need to replace a straight six foot section of cast iron waste pipe that is rotted and leaking. The old line has a flare on one end and a straight end where it fits into the other end of the line. How do I make the connections using pvc pipe
DKPE is offline   Reply With Quote
Old 11-18-2012, 08:22 AM   #2
Super Moderator
Rubber doughnut and Fernco rubber coupling---
at the hub---slip the rubber ring onto the PVC pipe---then use a hammer and wood block to drive the pipe/hub adapter (doughnut) into the hub----
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 10:29 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 05:13 PM
waste line in basement slab 7474 Plumbing 6 12-11-2008 07:38 AM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 08:10 AM
