-   -   main waste line repair in basement (http://www.diychatroom.com/f7/main-waste-line-repair-basement-163798/)
DKPE 11-18-2012 08:08 AM
I need to replace a straight six foot section of cast iron waste pipe that is rotted and leaking. The old line has a flare on one end and a straight end where it fits into the other end of the line. How do I make the connections using pvc pipe
oh'mike 11-18-2012 08:22 AM
Rubber doughnut and Fernco rubber coupling---
at the hub---slip the rubber ring onto the PVC pipe---then use a hammer and wood block to drive the pipe/hub adapter (doughnut) into the hub----
