Old 10-31-2006, 01:19 AM   #1
Default Main valve not working. Water won't turn on!
Hi,
My house is a 1920 two-story in Upstate, NY. Tonight, I went to the basement and I turned off the main water valve to bleed my pipes. I had a slight water hammer problem. When I went to turn off the water, I knew something was wrong.
My old valve has a circular knob on it like a garden hose spicket. I had to turn it 20 times or so to get the water to shut. The problem now is that the valve seems to be spinning and spinning but the water dosen't seem to flow almost as it it's stuck in the closed position.
Is my valve broken? I now have no water flowing in the house. From what I see it looks like a trip to HD, a new valve and my big wrenches will do the trick. But how do fix this problem.
Or do I need to call a plumber? I've included a pic to show you my antique main water valve which is on the far right of the picture. Please Help!
Thank you.
Ivan.
skellies is offline   Reply With Quote
Old 10-31-2006, 04:17 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
You probably need to replace this valve, it looks like there is a mix of copper and galv pipe, shutting the water off at meter will be 1st step, open outside hose to let pressure off line, then you will need to cut the copper to the left of picture with tubing cutters, then unscrew the old shut off from the pipe, then there are a few ways to reconnect the pipe back together after you ger new valve installed, there is re-solder it back together, pex it back together, I would use pex, but soldering might be best for you if you know how to sweat copper, if this all sounds difficult, then call a plumber in for help.
Ron The Plumber is offline   Reply With Quote
More On This Topic
Hi! I'm Arnesia Frances from Bell Nursery in Burtonville, MD for Expert Village. We are going to help you get your garden ready for the Winter. This is probably going to be the last time that I water out here because it is really starting to get cold and... Read More »
Hi! This John on behalf of Expert Village. In this video clip I will show you how to locate your main water shutoff. In most houses your main water shutoff is located in the basement, in the laundry room, in the most inconvenient spot possible. So the... Read More »
I’m Lee. I have a degree in architecture and about ten years experience in construction field and today we are doing a kitchen remodel and we have to cut the hot water pipe back about four to five feet away from where it should be. So what you want... Read More »
We've all heard the frantic request from the bathroom to bring the toilet plunger before the toilet runs over. All of us will cope with a toilet malfunction at one time or another. Some repairs are best left to the experts, but many fixes are simple once... Read More »
Hey everybody it's Don Golden with Expert Village and we are back outside. Why is that? Because we are almost done with this project. The shower, the cartridge is in and now all we've got to do is turn the water back on and see how it is working. Now I... Read More »
Main water shutoff problem GoodoleBob Plumbing 17 08-27-2008 10:53 PM
Replacing part of the Main Water line rgmetro Plumbing 2 04-12-2007 10:30 AM
Turning valve at water meter KCnorthernCA Plumbing 15 10-23-2006 01:35 AM
leaking water main LanterDan Plumbing 4 08-31-2006 09:24 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 12:31 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
