Main Stack Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-13-2009, 02:20 PM   #1
Main stack issue
Our house is 100 years old and in that time the house has shifted. Our problem is that the slope of the main stack were it leaves the house is now level instead of at an angle and we need to know how to get the angle back so it drains. Thanks
Elka is offline   Reply With Quote
Old 10-13-2009, 11:25 PM   #2
I think you mean the building drain. Assuming the house has sunk some and the horizontal is flat then you need to replace the drain al the way where it is deep enough to get your 1/4" slope.
plumber Jim is offline   Reply With Quote
Old 10-14-2009, 07:15 AM   #3
I should of mentioned
the basement looks like it was dug out some time after the house was built because the the part of the stack that goes to the street that has droped it about half way up the wall like it looks like i could take a jack and jack it up then build a wall to support it but don't know if that would work
Old 10-14-2009, 10:17 PM   #4
Do you mean that the basement used to be a crawlspace that was dug out to be a full basement and the drain pipe that was in the ground is now hanging? A picture would help.
Type of pipe for main stack to septic tank GD73 Plumbing 2 08-28-2009 10:17 PM
cutting tip plate for main stack rtoni Building & Construction 4 03-09-2009 03:34 PM
Tie into main kitchen stack gdub1973 Plumbing 1 08-02-2008 04:23 PM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 02:47 PM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 12:56 PM
