Main Shutoff Valve Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-28-2009, 01:24 PM   #1
I noticed a drop of water at the main shut-off valve off on the house side of the water meter, There was also some green residue on the beam underneath the valve and when I ran my finger along the underneath of the valve, there was green residue there as well so clearly, there is a slight drip. Its not a lot, but enough to show that there is a drip. (Picture attached)
Not sure if this is related, but the reason I went into the utiliy room in the first place was because I was hearing some water hammer noises as my dishwasher was going through its cycle.
I guess my question is am I due for a visit from my friendly neighborhood plumber to solve this or is this something I can easily solve on my own(and how?)
Many thanks for the advice...
coolptnr is offline   Reply With Quote
Old 11-28-2009, 04:20 PM   #2
Rewards Points: 1,536
You can fix it yourself provided:
1. There is another shutoff valve on the wall side of the meter (may be outside for example under a cover plate in the sidewalk),
2. You don't break any tamper detecting wires or strips or seals.
There are hex shaped rings at the meter so you can disconnect the pipes from the meter quickly without having to disassemble anything else.
Drain both hot and cold water from the entire system (excluding the water heater) using faucets upstairs and/or a basement laundry tub so only a small amount drains out at the work site as you unscrew the meter connection.
Add or replace some teflon tape if it is the screw joint that is leaking,
Old 11-28-2009, 04:49 PM   #3
Allanj
Thanks!!...this is quite helpful.
CP
Old 12-04-2009, 12:02 PM   #4
Rewards Points: 150
I would notify your water dept.as this is there equipment and responsibility to fix.
rudolph58 is offline   Reply With Quote
water main RonFromSeattle Plumbing 6 06-18-2009 06:11 PM
Price Pfister 3 Valve Shower Replacement water issue LeviDIY Plumbing 3 06-18-2009 01:59 PM
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 10:49 AM
Rheem water heater gas valve issue tsherv Plumbing 4 05-26-2009 09:38 AM
Master (water) shutoff valve rmdyjoe Plumbing 7 12-05-2008 08:55 AM
