Main Shut Off Water Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-18-2010, 09:19 AM   #1
main shut off water valve
I'm looking for my main shut off water valve. The meter is only a meter and I can't tell where the water comes into the house. I live in a house that is about 5 years old and in a gated neighborhood...not sure if that makes a difference.
dragons73 is offline   Reply With Quote
Old 12-18-2010, 09:44 AM   #2
trace the supply line back from your hot water heater. at some point there will be a branch which goes to your other cold water fixtures. that should be pretty close to where the supply enters the house. if there is no shut off valve at that point, then it must be outside. if thats the case, there should be some kind of access cover near the water meter.
1910NE is offline   Reply With Quote
Old 12-18-2010, 12:46 PM   #3
Usually the water meter is located on the front side of the house. along the foundation wall. If your basement is finished that makes tracing water lines harder. Lokk in your mechanical room. Under you staircase. or in an unfinished part of the basement. It is possible the meter is outside in a pit. If all else fails call your municipal water dept. and ask them if they could locate your meter for you. Usually this is a free service by them.
Work4living is offline   Reply With Quote
Supply valve to bath faucet doesn't stop water Kurt123 Plumbing 2 09-05-2010 09:48 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 01:36 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
dripping from water shut off valve underneath the toilet maitri Plumbing 4 12-10-2006 03:58 PM
