Main Sewer - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-20-2008, 10:21 PM   #1
Main Sewer
Hi i live in Wisconsin, i have a basment and went down there past 2 days and noticed some sludge around the floor drain in the basement, i called the DPW and they checked sewer and its good, and said i probably need to have the drain in basement that leads to the sewer line cleaned, he said i could do myself how would i go about doing this, and is this better to call a plumber
CJBSHM is offline   Reply With Quote
Old 11-21-2008, 07:09 PM   #2
you can do it yourself, its not hard, simply go to a equipment rental store and rent and auger(snake). Remove cap from drain plug in auger and thread through the line, if something is clogged in there, this will more then likely remove it.
zosoplumber is offline   Reply With Quote
Old 11-21-2008, 07:50 PM   #3
I feel the need to comment that although an auger/power snake will clear the pipe, you need some idea how it works. I guess its one of those tools that seems harmless enough until it grabs you.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 11-22-2008, 02:33 PM   #4
Thats true Dude, i should have mentioned the dangers of being "grabed", hopefully they come with instruction, just don't wear any loose clothing or loose gloves while working it.
Sewer main NEW LINING? DragonLady Building & Construction 2 11-02-2007 06:46 PM
DIY replacement of a section of sewer main jcarlsonNSP Plumbing 3 10-03-2007 01:00 AM
Sewer gas smell in basement when doing laundry on main floor Bornintc Plumbing 1 01-17-2007 12:04 PM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 08:10 AM
sewer main line repar Babar Plumbing 1 01-26-2004 07:39 AM
