Main Plumbing Stack 3" Code Comply Or 4" - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-12-2011, 04:59 AM   #1
Rewards Points: 562
main plumbing stack 3" code comply or 4"
Does a 3" stack/vent comply with all codes? Simple small home , connected to within 5',,,kitchen sink,,,, (NO dishwasher),,,, laundry washer drain,,,,, (normal bath fixtures) stool sink and tub/shower. Just one bathroom in this single story house.
What are advantages and disadvantages of 4" pipe???? 3 would fit so much better. Heard it had better flow than 4,,,true or not???
4just1don is offline   Reply With Quote
Old 08-12-2011, 08:45 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 816
The simple answer is to contact your plumbing inspector. The fixtures you list could be vented on 2". But since that is all of the fixtures in your house, the cross sectional area of the vent needs to be at least equal to the area of the bldg drain, which in your case is 3". To add a twist--My state says all bldg drains must be 4" exiting the bldg regardless of the fixture load. Every plumber here has different code variations so you might here different answers.
Old 08-12-2011, 09:08 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Our code says it has to be equal to the MINIMUM REQUIRED building drain.
So we could stub out an 8" building drain and still only require equivalent to a 3" vent.
Why would we do that? We wouldn't, but it sure would be fun to drive around with 8" pipe on the truck all day.
Journeyman Plumber
3" Remodel Recessed Lighting Question - Code easelpad Electrical 2 01-07-2011 08:29 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Can I comply with code in this situation? pcampbell Electrical 10 11-15-2008 07:32 AM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 08:55 PM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 12:56 PM
