Main Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-23-2013, 07:38 PM   #1
Rewards Points: 112
Main leak
How should I deal with this, there is a small leak and I figure I may as well tidy it up:
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 06-23-2013, 07:47 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by digitalplumber View Post
How should I deal with this...
What is on the OTHER side of the brick?
In short though... I'd say you should re do the whole set up.
Old 06-23-2013, 07:51 PM   #3
Rewards Points: 112
Bedroom, sheetrock. Actually what happened was this was hit with lawn mower and cracked lower threaded PVC into bottom of brass valve. We replaced as you can see with no leak! But another leak then appeared in the top threaded pvc to the brass valve.
So we did the best for tonight, in order to have water for overnight and in the morning. I was thinking that surely there is an easier way to redo all of this.
Sorry my first post was so lacking in info.
Old 06-23-2013, 08:01 PM   #4
Redo it all
Cut the insulation away
Cut at the bottom part of PVC
Replace everything with new parts
Take the thing to your local plumbing supply house
Show them it
Ask them to rebuild it or tell you how
Reconnect with two PVC unions for future repair.
davidblackwoods is offline   Reply With Quote
Old 06-23-2013, 08:48 PM   #5
Lord of Slums
Rewards Points: 1,974
Help me understand this, that is your house main coming up from the ground and going into the house? Why so high up on the wall? I would run the new onw through something so it is never damaged again
mj12 is offline   Reply With Quote
Old 06-23-2013, 08:55 PM   #6
Rewards Points: 112
Sons house, built in 60's probably. It's really not that high.
Old 06-23-2013, 09:00 PM   #7
Rewards Points: 112
What's the difference between a grey PVC union and a white one?
Old 06-23-2013, 10:20 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 910
Grey is sch 80.
If I was making the repair- I'd make as much as I could with galv. pipe. Then you could hit it with a lawn mower......
Just a reminder- do not use any pvc female adapters. They are known to crack/split.
The Following User Says Thank You to TheEplumber For This Useful Post:
digitalplumber (06-23-2013)
Why would faucet leak when shut off at main supply? barbienot Plumbing 6 01-29-2012 07:00 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 01:26 PM
Dual Main Breakers dcwestcott Electrical 3 02-23-2009 07:26 PM
Help with water main seal leak! Taipans Building & Construction 2 03-18-2008 08:06 PM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
