Main Drain Replacement? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-03-2012, 12:55 PM   #1
I have a half bath with a toilet and sink. There is a 4" cast iron main drain running through the floor. I'm planning to convert the sink to a double sink and install a bath tub. According to the code, when I pull a permit and do the inspection, would they require me to replace the entire main drain which runs into the laundry room also or can I break the slab and tap into the existing drain line? Will they inspect all of the plumbing in the bathroom or just the modifications to add a double sink and the tub?
There are also old supply lines from the sink which I can tap into. Would they require me to replace all the old supply lines in the bathroom or can I tap into them?
The city uses the 2006 IPC and it's in Norfolk, VA.
Thank you for your help! I'm just trying to get it right the first time.
kingbuggy is offline   Reply With Quote
Old 05-03-2012, 07:20 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Im not sure why you couldnt tie into the existing groundwork if its in good shape still,if theres any doubt in its condition Id go ahead and replace it while floor is open though.
Your venting might be an issue depepending on existing conditions.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 05-03-2012, 10:26 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
My personal opinion aligns with plummen's
If you are busting up concrete : Replace the entire line. You don't want to end up with brand new finished floors and walls and end up with a big sewage backup and have to start over again.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
plummen (05-03-2012)
Old 05-04-2012, 07:58 AM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 984
Before you start anything I would make a drawing of what youíre planning and a drawing of how you plan on piping it in. go see the plumbing inspector and go over it with him. Show fittings and venting and pipe sizes in the rough above and below ground for drain and supply. You need only test the new work, existing lines must run dry. If they donít that may be an issue. Hopefully you are able to pull an owners permit, here home owners cannot pull plumbing permits for DIY work, must be done by a plumbing contractor. Good luck on your job.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 03:09 AM
Tap 2" Drain Pipe into 4" PVC Main Sewer Drain Pipe brmatthews Plumbing 3 12-20-2010 08:49 PM
Water Main Replacement Advice Crashless Plumbing 8 08-11-2009 07:15 AM
Bathtub drain replacement ex-Khobar Andy Plumbing 1 07-15-2009 05:17 AM
roots in main drain jerry1967 Plumbing 5 10-28-2008 04:57 PM
