Old 04-06-2006, 12:58 AM   #1
Main drain line
I made my bathroom bigger and will be relocating the bath and toilet and sink.I bought a new 1.6 gpf toilet and wondering is 3 inch big enough for the main line that runs to the septic.I made the hole for the flange 5 inch being I planned on 4 inch pvc and the flange is 5 inch outside.I was told by a friend 3 inch is plenty big enough.Now if I bought a flange for 3 inch would it be big enough to go out past my 5 inch hole on the floor surronding it so that I can screw it to the floor or am I stuck using 4 inch now.Now the original cast iron pipe looks to be 4 inch inside and using a fernco fitting would it be fine to go from say 3 inch pvc to the cast or does it have to be the same size for the fitting to seal ok.
lmanwarren is offline   Reply With Quote
Old 04-06-2006, 01:32 AM   #2
renovations
Main drain line
The flange for the 3" will fit fine, 3" is good to use and you can adapt it no problem. There's ferncos that are made for that. I'd say you're good to go!
Bonus is offline   Reply With Quote
Severed septic drain field line tripower Plumbing 2 08-14-2007 02:05 PM
Problem with Main Line or Not? reibuild Plumbing 2 05-02-2007 11:41 AM
Cutting Concrete for drain line Piney Building & Construction 2 12-01-2006 08:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 12:13 AM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 08:10 AM
