Old 03-20-2009, 03:53 PM   #1
Main Drain Assembley--What is This?
See the attached Photo. I have a slow draining shower that I have been trying to clear from the main shower drain. The shower drain assembly comes into the "chamber" and then angles into the main drain stack. The shower drain and overflow appear to be copper to galvinized to cast iron. Is the "chamber" the trap for the shower? Can the nut on the bottom be loosened to attempt to clear the blockage at either end of this "chamber"?
Dave
wsuswim147 is offline   Reply With Quote
Old 03-20-2009, 03:55 PM   #2
That is a drum trap with a removable clean out plug.
Be very careful trying to remove it. I would soak it down good with a penetrating spray such as PB Blaster and let it sit overnight.
You may try tapping the drum lightly with a hammer while applying torque to the cap nut.
Sometimes heat from a torch may help. (But not in the presence of penetrating oil!)
porchmonkey is offline   Reply With Quote
Old 03-20-2009, 03:57 PM   #3
Yes, this is called a drum trap. Although the cap/plug on the bottom is made for cleaning out, they are usually so corroded they will not budge. Most I have seen have the cap in an upwards position and are accessible through the floor. I included a link that may help you. Just click on the link.
http://www.ehow.com/how_2099070_clea...paign=yssp_art
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 03-20-2009, 04:01 PM   #4
O.K. Thanks.
So if in theory I was able to remove the plug and get access to the trap:
1. Whould I be able to get to both ends of the pipe to try and clear the blockage?
2. If I got the cap off, would it be a nightmare to get it back on with a watertight seal?
Old 03-20-2009, 04:04 PM   #5
1. Yes
2. If it comes off in one piece and the threads are good, it should go back on. Use pipe dope.
Old 03-20-2009, 06:41 PM   #6
Looks to me like with that drum you have 4 X 90 turns and a 45 elbow within 24".
Good potential for repeat problems.
Chemist1961 is offline   Reply With Quote
Water Backing up Though hole in basement dynamis Plumbing 3 06-15-2009 06:11 PM
Leaking main drain clean out plug bucksone Plumbing 1 01-10-2009 08:42 AM
roots in main drain jerry1967 Plumbing 5 10-28-2008 04:57 PM
Finding the main drain pipe in my basement floor? jbravo8212 Plumbing 1 01-30-2008 11:20 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
