Main Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-24-2013, 04:34 PM   #1
Main drain
Hoping for some help
My main drain was/is clogged so I scooped up all the standing water, removed tthe vent and removed the side plug out of the drain with the intent to snake it but as soon as I did that all of the water immediatley drained thru the side plug but when I put the side plug back on its still clogged.
2 questions
First, where should I snake next to clear the clog?
Second, is there any reason I need to put the side plug back into the main drain or can I just leave it out for good?
Ryan1122 is offline   Reply With Quote
Old 08-24-2013, 05:44 PM   #2
Rewards Points: 582
2 questions
we really need a picture of what you are doing...sounds like your at the base of a stack .and you opened a clean out....not sure of what you mean when you say you removed the vent ben sr
Old 08-24-2013, 06:45 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 432
If it truly was a clean out plug that released sewage then the blockage is downstream from there.
I suggest hiring a plumber with a mainline machine for 3" or 4" lines. If it's a smaller line you can probably tackle the blockage. Machines are available at the rental yard
Old 08-26-2013, 10:33 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 986
I think this is a one hit wonder.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 08-27-2013, 07:14 PM   #5
Rewards Points: 1,766
I guess you can leave the clean out plug off and fill your basement with sewage. I can't smell it from my house so it's fine with me.
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 03:09 AM
Main ABS Drain Pipe Leakage Unclev Plumbing 8 03-03-2012 07:03 PM
Leaking main drain clean out plug. dakornblum Plumbing 2 10-26-2010 07:20 AM
Partially blocked main drain? jimithing78 Plumbing 4 05-31-2010 02:29 PM
water backing up from main drain rpowers Plumbing 6 02-28-2010 03:52 PM
