Main Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-13-2012, 12:26 PM   #1
Main Drain
I own a house that was built in 1952. About 6 years ago I replaced the Main Drain line. For the past 4 yrs I have to be careful doing laundry because the drain is real slow. I've checked the vent pipe and it seems to be clear. I've also put baking soda and vinegar with boiling water down the kitchen sink which is directly above the main drain. What's next? I've had it snaked, and just a tiny bit of lint comes up. The plumber seems to think it's do to the pipes being so old and lots of lint just collecting on the sides.
anneinfairfax is offline   Reply With Quote
Old 03-13-2012, 12:40 PM   #2
Owner
LateralConcepts's Avatar
We need a bit more information. You mentioned you replaced the "main drain line" 6 years ago. What do you mean by that? Did you do it yourself or did you hire someone to do it? When you say 'main drain" do you mean the 4" sewer lateral from the house all the way to the street? Is it just the laundry that's slow? Are you on city sewer or septic? If the line has been replaced, why would a plumber seem to think it's due to "the pipes being so old"?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
The Following User Says Thank You to LateralConcepts For This Useful Post:
plummen (03-13-2012)
Old 03-13-2012, 01:03 PM   #3
I had a company do it and yes, it's the sewer line from the house to the street. I'm on city water and it's just the laundry that's slow. He's referring to the pipes under the house.
Old 03-13-2012, 01:47 PM   #4
Owner
If you can, take a picture of your laundry setup and post it.
Lateral
(208) 818-8241
Old 03-13-2012, 02:45 PM   #5
I will do that tonight when I get home.
Old 03-13-2012, 07:12 PM   #6
Here's a picture of the set up. I hope this helps. Thanks for looking.
Name:  fairfax_laundry (Custom).JPG
Old 03-13-2012, 07:31 PM   #7
Rewards Points: 180
So when you replace the main line, did you replace the lines under the house? Does the laundry tie in before everything else? Do you have access under the house or is this a slab foundation?
KarlJay is offline   Reply With Quote
Old 03-13-2012, 07:40 PM   #8
No. We did not replace the lines under the house and there is no access as it's on a slab foundation. I'm not sure what you mean "tie in before everything else". The laundry empties into the tub. It's in the back of the house and the kitchen is above it. Does that help?
Here is a link to the full size picture:
http://imgur.com/a/pUVII#0
Old 03-13-2012, 10:18 PM   #9
Owner
Attachment 47445
Yes the picture helps. That's a very common problem. I see you've taken some steps in helping to remedy the problem. i.e. the lint filter (screen) over your washing machine discharge is a good idea. The biggest problem however, is that you have (what was a common set-up at the time), the kitchen and laundry tied into the same 1 1/2 or 2" galvanized drain line (can't tell size from the pic). If it's 1 1/2" it's undersized. 2" is required for kitchen and laundry. Additionally, the kitchen and laundry drains are the two most likely in the house for being subject to abuse. i.e. grease, food waste, soap scum, etc. from the kitchen; and virtually the same including including lint from the laundry. The two discharging into an old galvanized drainage system is trouble waiting to happen. The inside of that pipe is probably necked down to less than 1/2" in spots due to build-up of grease waste, lint, etc. The only cure is to re-plumb (eliminate the old galvanized). The only way to avoid that; but still greatly improve the flow characteristics, would be to jet the line out with a high pressure jetter. Jet the line from the cleanout under the kitchen sink, all the way to where that line ties into the 4" main. Keep in mind, this can make a huge mess if you're not careful. If you're not comfortable doing it yourself, hire a professional.
Lateral
(208) 818-8241
TheEplumber (03-13-2012)
Old 03-14-2012, 06:19 AM   #10
I had a feeling I needed to jet the line but was trying to avoid it because of the expense and wasn't sure where to jet from. So, that helps immensely!!! Thanks ever so much....I'll let you know what happens.
The Following User Says Thank You to anneinfairfax For This Useful Post:
LateralConcepts (03-14-2012)
Old 03-20-2012, 10:39 AM   #11
Well, I had Roto Rooter come to the house on Saturday and he didn't want to jet from the kitchen (he said it would make too much of a mess) so he instead jetted from the vent pipe. Besides the mess I had to clean up in the basement (2 hrs) and the cost ($1500) it worked! I ran the dishwasher and a load of laundry at the same time on Saturday night and it went down perfectly!!! Thanks!!!!
Old 03-20-2012, 11:34 AM   #12
Owner
Glad it works. $1,500 and they had you clean up the mess? Hmm interesting
Lateral
(208) 818-8241
Main ABS Drain Pipe Leakage Unclev Plumbing 8 03-03-2012 06:03 PM
Leaking main drain clean out plug. dakornblum Plumbing 2 10-26-2010 06:20 AM
Partially blocked main drain? jimithing78 Plumbing 4 05-31-2010 01:29 PM
water backing up from main drain rpowers Plumbing 6 02-28-2010 02:52 PM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
