Main Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-08-2012, 09:08 AM   #1
main drain
what is the measurment from the mail waste (pipe in the wall) to the floor, when installing a undermount sink?
Do I need to lower this drain pipe for an undermount sink ?
buckrd is offline   Reply With Quote
Old 03-08-2012, 09:32 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
It depends on a lot of things.
Is your coutertop height standard? Do you have a normal sized undermount sink or is it extra deep?
We normally go 16" for kitchen sink drains and 19" for lavatory drains. If they're planning on having an extra deep sink sometimes it's best to go a few inches lower.
If it's a triple bowl, sometimes you need to be really low, depending on configuration of the bowls.
Journeyman Plumber
Old 03-08-2012, 11:08 AM   #3
MY drain measures at 19 inchs, I live in Chicago. I will have a deep bowl SS sink with Disposer with standard top,and cabinets, you think if i drop it down 4,, around 15'' inchs this will work for me.
Old 03-08-2012, 03:42 PM   #4
Rewards Points: 636
it sounds low but kitchen sinks i rough in at 12 to 14 inches due to under mount deep bowl with garbage disposal scenario's that i get in remodel sink reworks when the customer can not figure out why i need to cut drywall when it worked before.for those "i just need you to hook my sink up after new counter top calls"
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
buckrd (03-08-2012)
Main ABS Drain Pipe Leakage Unclev Plumbing 8 03-03-2012 06:03 PM
Leaking main drain clean out plug. dakornblum Plumbing 2 10-26-2010 06:20 AM
Partially blocked main drain? jimithing78 Plumbing 4 05-31-2010 01:29 PM
water backing up from main drain rpowers Plumbing 6 02-28-2010 02:52 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
