Luck Warm Water To The Shower... Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-01-2009, 10:05 AM   #1
Luck warm water to the shower... Help
We are in the process of remodeling and I am doing the plumbing.
To make this really simple draw a T on a piece of paper. The vertical part of the T connects to the hot water heater and is 3/4" copper. The left side of the T is 3/4" copper that runs to the kitchen, a secondary bathroom and the laundry room. This side of the supply line is 3/4" to the kitchen where it is reduced to 1/2". The 1/2" line feeds the sink, shower and laundry.
The right side of the T was immediately reduced to 1/2" and that feed the main bathroom (shower and sink).
We are in the process of adding a new basement bathroom directly below the main bathroom and I was concerned that a 1/2" supply line would not be sufficient for both bathrooms. So I upgraded the 1/2" supply line to 3/4" and then broke off with 1/2" T fittings for the main shower and faucet and then again to the new shower and faucet.
So basically I have a straight 3/4" supply line from the hot water heater that has 4 T fittings (each 3/4" to 1/2") for each faucet and shower. I hope that makes sense.
The problem is that since doing this our main bath/shower is only getting warm water even with no other fixture on. Initially it is hot but then it drops down to luck warm and we can't seem to get it any hotter.
So the question is should I have only upgraded the supply line to 3/4" to the first fixture and then continued with 1/2" to the other fixtures?
Sorry for the long description... any help would be greatly appreciated.
Thanks.
bwendt is offline   Reply With Quote
Old 03-01-2009, 01:03 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Sounds like you have a problem with that shower valve. If all other fixtures are hot then there is a setting on the valve itself or you have an internal problem
Old 03-02-2009, 12:23 PM   #3
Send a message via AIM to rh8868 Send a message via MSN to rh8868
Is it possible your shower has some type of ?anti-scald? setting that is set ridiculously low by default from the manufacturer?
rh8868 is offline   Reply With Quote
low hot water pressure in shower avlivewire Plumbing 2 10-18-2008 02:32 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
Weak stream of water from shower head. SuperAkuma Plumbing 3 08-01-2008 05:49 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Hot water pressure in the shower Randy Stuempfig Plumbing 15 01-03-2008 09:58 AM
