Old 12-12-2007, 03:24 PM   #1
LPG pipe sizing information
Can somebody point me to a reference for sizing pipes for a LPG system (residential). As part of our remodel we are adding a gas range, gas line to the fireplace, and a larger furnace.
I'm concerned my current LPG piping system is not sufficient for the added loads. My current system supplies a water heater and a furnace.
Thanks in advance....
steve1234 is offline   Reply With Quote
Old 12-14-2007, 11:18 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Check you building codes there, there should be some kind of flow chart you have to follow.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
washer drain pipe paydelady Plumbing 3 11-13-2007 01:27 AM
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 04:08 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
