LP Gas High Pressure Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-20-2011, 10:50 AM   #1
Still going...
ChrisDIY's Avatar
Rewards Points: 508
LP gas high pressure line
Hello!
Does anyone know of there are any regulations that prohibit a high pressure LP line from running through the residence? When they installed the outside high pressure line they hit my septic pipe and it had to be repaired. Preparing for generator install and septic line follows the outside perimeter of the house where future LP line will need to run and I'm sure they'll hit it again. PVC pipe so no real way to locate it. I guess this also would be determined by whether the regulator can be installed next to generator?
If not will be forced to run generator wires through house a 30-40 foot run one way, so aluminum. I don't even want to know how much copper would be.
Need to avoid trenching.
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 10-20-2011, 05:21 PM   #2
Rewards Points: 760
FYI, generators are usually located nearer the gas service so you don't have long runs of pipe.
30-40 feet of wire is not a long distance. What size generator?
How much is the gas line? You using copper?
AandPDan is offline   Reply With Quote
Old 10-20-2011, 05:32 PM   #3
Still going...
ChrisDIY's Avatar
Rewards Points: 508
20 Kw, that's $800 of copper wire...
If I am going to have to favor one outcome over another I will put it as close to the LP regulator as possible and have wires run to it. Have electrician put it in conduit, I can't have any more trenching.
--Chris the DIY Guy
Old 10-20-2011, 06:06 PM   #4
Rewards Points: 760
That's not just for the wire, you MUST be including installation.
#4 THWN in PVC conduit?
Even at the Orange store you can get 500' for less than $1 a foot.
Old 10-20-2011, 10:03 PM   #5
Still going...
ChrisDIY's Avatar
Rewards Points: 508
I was under the impression I needed 2/0 wire. Normally the wire would exit the house, enter the ground and come back up at generator. I would be doing the entire wire above ground so inside of conduit, i.e. no trenching. GIven my initial question generator may have to be 5' from house.
--Chris the DIY Guy
Old 10-21-2011, 08:41 AM   #6
Rewards Points: 760
What does the installer suggest? You're only taking the feed from the generator to your transfer switch which should be located very close to the panel.
You may/may not be able to use #4 due to the temp rating, 60c vs. 75c degree ratings, but, #3 cu is rated for 85 and #2 cu is rated at 95 amps, at 60c.
Check with you local AHJ.
2/0 is rated at 145 amps.
Old 10-21-2011, 10:59 AM   #7
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Thanks!
I need more help on the LP line than the electrical, actually.
--Chris the DIY Guy
lennox xp15 high pressure fault code GEAF HVAC 10 03-11-2011 08:44 PM
Water Pressure issues after repairing main water line. Cleve99 Plumbing 2 01-26-2011 07:13 PM
High pressure Shower Head Carloscda Plumbing 9 06-18-2010 12:50 AM
Running a secondary high pressure line Randell Tarin General DIY Discussions 6 02-18-2008 11:39 AM
