Old 07-09-2010, 07:41 AM   #1
lowering iron sink drain in kitchen wall
I put in a new/used kitchen sink in the house I ren, since there's no dishwasher and the double basins made more sense. Problem now is with the disposal, the sink outlet is about 1/2" lower than where the old steel pipe enters the wall. I opened the wall up to get a look see and the pipe doesn't seem to be strapped anywhere I could see and the vent, although going up from that five pound tee, has to go around the window that is about three feet above. I want to cut the pipe about 2" below the tee so I can put in a fernco san. tee, (all rubber tee with pipe clamps), but I'm not sure what will effectively cut through that heavy steel pipe without starting a fire, plus, I don't know if the pipe below the tee is secured or supported and worried it could fall down into the wall or down into that nasty old crawl space in this 1940 bilt old house!!! Any knowledgeable HELLLLPPPP??? out there. I don't want this to end up costing more than the monthly rent!!!
leeb is offline   Reply With Quote
Old 07-09-2010, 10:09 AM   #2
Doing it myself
Alan's Avatar
Do you still have the black 90* fitting on the disposer?
Journeyman Plumber
Old 07-09-2010, 10:11 AM   #3
Doing it myself
Alan's Avatar
Is it already hooked up like this ? This configuration gives the most clearance below the sink.
Journeyman Plumber
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
adding new sink / faucet / drain assembly... and I'm clueless :-( diy'er on LI Plumbing 4 11-13-2009 06:36 PM
Clogged Kitchen sink drain hornsby Plumbing 2 07-23-2009 10:46 PM
Bathroom Sink Drain (Broken from wall to Ground) bli182nk Plumbing 2 01-11-2009 08:52 PM
Kitchen Sink Drain powrus Plumbing 4 12-06-2007 06:58 AM
