#1 |
On the lower level of my condo, I have a bathroom that when the toilet flushed, the s
Help! Drain over-flows when toliet flushes.
On the lower level of my condo, I have a bathroom that when the toilet flushed, the sewage backed up from my furnace drain. I ran to home-depot, bought a snake and ran it all the way to the sewage pit/sewage ejector.I believe I opened up the clog enough that the toilet can flush without a problem but I did notice something. When I flush the toilet, the water level in the drain slightly rises and slowly falls. It this normal? Should I even see water in the drain? Last edited by tomgoral; 07-13-2010 at 10:42 AM. Reason: tried to delete post and add a title, no clue. |
#2 |
Owner
There should always be standing water in the floor drain because it has a p-trap under the floor. If it fluctuates when you flush though, that means there's some type of blockage in the main. Sounds like a soft/sludgy/greasy blockage in the line before it ties into the pump basin.
I would also test your pump. Is the pump making any noise? Humming? Your pump has a piggy back plug. You'll be able to manually run the pump by unplugging it and plugging in the top plug only. If you hear the pump run and discharge the pump is operating normally. If not, and it just makes a humming sound, unplug it. The pump will need to be pulled from the basin and either cleared or replaced.
Brad Penske, Operations Manager - Coeur d'Alene, ID LateralCONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting (208) 818-8241 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to LateralConcepts For This Useful Post: | tomgoral (07-15-2010) |
| Display Modes | |
| Toilet issue: Shims, wax, general disarray. | dawho1 | Plumbing | 8 | 01-23-2010 08:38 PM |
| Bad damage to area in lower level | 68MHJCs | Building & Construction | 3 | 01-03-2010 12:30 PM |
| Toilet install - 2 questions | BataviaJim | Plumbing | 11 | 05-11-2009 02:53 PM |
| need heat suggestion for lower level | dallison | HVAC | 6 | 02-20-2007 07:54 PM |
| Water level in toilet bowl | Kath | Plumbing | 10 | 06-22-2006 04:26 PM |
