Low Water Table Or Faulty Pump??? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-09-2017, 12:32 PM   #1
Low water table or faulty pump???
When I run a usual amount of water, say a long shower or a load of laundry, the water runs out and I have to manually shut the pump off otherwise it overheats and loses its prime.i was thinking it was a shallow water table do to the dry summer and was going to have the well drilled deeper this spring. It's a shallow, drilled, well.
DoSomething is offline   Reply With Quote
Old 01-09-2017, 12:37 PM   #2
Also to be know is there are plenty of springs around the house, during heavy rain they literally come up threw the lawn. Water can be hard running into the well being shooting free, very very wet around the house this fall. So I'm second guessing this being a problem with a shallow well and feeding water table
Old 01-09-2017, 12:40 PM   #3
joed's Avatar
Rewards Points: 12,446
Re: Low water table or faulty pump???
Shallow well pump can draw about 25 feet of water. If the level in your well drops below 25 feet of the pump then can lose suction.
The only to know for sure is to check the water level in the well.
Hot water from cold pipes, plumbers are stumped seabeast Plumbing 75 03-31-2015 09:52 PM
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Heat Pump Water Heater Review wassermeister Plumbing 0 08-25-2012 03:35 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
